0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | The truck came with no keys to doors or ignition. Has anyone else had to deal with this issue. would it be cheaper to replace the switch and handles or get a locksmith out.
1950 Chevy 3600
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Questions should state a specific model of truck. This site covers trucks made over a 50 some year period.
If perhaps your truck was made from 1952 to 1966 the door lock cylinder will have the code stamped on it. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | If this is the 1950 3600 from your other post the easiest is to pull the ignition switch and lock cylinder (labeling the wires as you go), take it to the locksmith to get keyed. The key should also fit the doors unless the ignition lock cylinder has been changed.
Ed
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Thanks Forty9, yes it is the 3600 from my other posts. Each day i get closer and closer to getting it running, but wont make it far without a key. I look up some locksmiths.
1950 Chevy 3600
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The '50 door lock should have the number on the outside of the assembly. No need to pull the cylinder. | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | cletis, what will the number tell me? can i match it with a number on the ignition.. or is a number for the locksmith?
1950 Chevy 3600
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The number is a code. A locksmith with a code book covering 1935-66 GM codes can cut a key using the code. I have a copy. If you can't find a locksmith with one PM me the code and I'll tell you what the cut is. Any locksmith should be able to cut one from that. | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Thanks Cletis I will look this evening and let you know.
1950 Chevy 3600
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Brad, To make your questions easier to understand and less hassle to you, add "1950/3600" to your profile.
~Jim
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Thanks Big Chevy, I a noob
1950 Chevy 3600
