3 members (Hotrod Lincoln, baldeagle, Lightholder's Dad), 42 guests, and 5 robots.
Topics128,018
Posts1,055,339
Members48,419
#870865 07/31/2012 10:34 AM
The truck came with no keys to doors or ignition. Has anyone else had to deal with this issue. would it be cheaper to replace the switch and handles or get a locksmith out.
1950 Chevy 3600
Bradw1876 #870867 07/31/2012 10:53 AM
Questions should state a specific model of truck. This site covers trucks made over a 50 some year period.
If perhaps your truck was made from 1952 to 1966 the door lock cylinder will have the code stamped on it.
Cletis #870870 07/31/2012 11:03 AM
If this is the 1950 3600 from your other post the easiest is to pull the ignition switch and lock cylinder (labeling the wires as you go), take it to the locksmith to get keyed. The key should also fit the doors unless the ignition lock cylinder has been changed.
Ed
Forty9 #870933 07/31/2012 3:02 PM
Thanks Forty9, yes it is the 3600 from my other posts. Each day i get closer and closer to getting it running, but wont make it far without a key. I look up some locksmiths.
1950 Chevy 3600
Bradw1876 #870948 07/31/2012 3:49 PM
The '50 door lock should have the number on the outside of the assembly. No need to pull the cylinder.
Cletis #870950 07/31/2012 3:55 PM
cletis, what will the number tell me? can i match it with a number on the ignition.. or is a number for the locksmith?
1950 Chevy 3600
Bradw1876 #870952 07/31/2012 4:04 PM
The number is a code. A locksmith with a code book covering 1935-66 GM codes can cut a key using the code. I have a copy. If you can't find a locksmith with one PM me the code and I'll tell you what the cut is. Any locksmith should be able to cut one from that.
Cletis #871475 08/02/2012 9:07 AM
Thanks Cletis I will look this evening and let you know.
1950 Chevy 3600
Bradw1876 #871482 08/02/2012 9:25 AM
Brad,
To make your questions easier to understand and less hassle to you, add "1950/3600" to your profile.
~Jim
BIG CHEVY 3600 #871506 08/02/2012 10:36 AM
Thanks Big Chevy, I a noob
1950 Chevy 3600
