6 members (Gdads51, Ponchogl, Otto Skorzeny, Wayne67vert, BillyDon, carbking), 126 guests, and 4 robots.
Topics128,272
Posts1,058,316
Members48,485
#870167 07/28/2012 5:02 PM
1950 3600 has rotted out the rear corners of the cab. Does anyone know where i can find a replacement set to weld in. Also, how hard is it to remove the bed. i will need to remove it to make some of the welds.
1950 Chevy 3600
Here are a few pictures (follow the links) on how I did mine. The clamps made it easy I bought them at HF for $8, I see them advertised for as much as $30 so go there they work fine.
http://good-times.webshots.com/photo/2265704470102454676pTFtwj
http://good-times.webshots.com/photo/2071953970102454676qiHynG
I welded mine in also. But I have heard good feedback on those that have"glued" theirs in. Theoretically at least as strong as a weld without the warping issues.
using glue instead of welding to attach 2 metal parts?
Thanks Guys. This is a little down the road for me, but its good to know it shouldn't be an issue locatig replacements. I wasn't looking forward to trying to manufacture that bend myself.
1950 Chevy 3600
3M 8081
I wouldn't use it for cab corners but it is structuraly valid.
Give me ambiguity
or give me something else
