1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Has anyone considered a pre oiler for their motors, if so what brand? Thanks Rick.... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What engine?
What pre-oiler?
| | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Cut the top off a old distributor housing and run the shaft with a 1/2" electric drill. Use what ever distributor fits the engine you need to pre-oil. Or use a bushing that fits the opening with a round shaft in a drill motor and the end ground down to fit the oil pump. There are lots of choices with out spending much money, it just takes a little manual labor.
Joe | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you do what Joe said, either take the gear off of the bottom of the dist. or grind the teeth off. That gear is engaged with the camshaft and with it on you won't be able to spin the oil pump. Unless you have a REALLY big drill motor.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Rick,
When you referred to a pre-oiler, were you referring to priming after a rebuild (or after sitting for a long period), or are you referring to a pre-oiler/pre-lube system that supposedly lessens cold-start scuffing?
| | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Let me clarify. Yes Tim I am thinking of a pre-lube system to limit dry starts after my sbc sits for a week or two. Sometimes circumstances prevent me from getting to the car for a couple of weeks so I thought a pre-lube system might help. So I was wondering if anyone has used them and if so what brand?
Rick......... | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Elmer, you must have experience with heavy duty engines to be aware of any need for pre lube or concerned about "dry starts". One of the great features of the SBC, in my opinion, is the bottom end design including the lube system. The oil pump submerged in the oil supply and a filter that will not drain back to the sump helps assure quick pressurization of the system and a proper viscosity of oil for the bearing clearances keeps the bearings well lubed until the pressure supply arrives. If you think the system goes dry at shutdown, just spend some time working under an engine with the pan removed to roll in or inspect the bearings.You'll soon be hunting for a raincoat and goggles. These engines with reasonable care will run 300,000 miles and have healthy bearings when you open them up and very seldom is the oil pump greatly worn.I like to do autopsy on an engine when dismantling for OH or repair.The wear patterns can tell you a lot about the operating conditions and needs. Diesels many times start under load and need pre lube for good bearing life but the automobile driver can be more considerate of cold start conditions. Just my 2 cents worth.
Bob Taylor
| | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | In the 70's I started to see ads for a starter with pre lube pump built on for heavy equipment and truck diesels but I never had experience with one. Basically it was a Delco type,solenoid engaged starter with a oil pump on the commutator end plate. The solenoid had been divorced from the starter motor circuit so operating the start switch first started the starter motor/pump turning,when oil pressure developed a pressure switch energized the solenoid, engaging the pinion gear.I don't know how this was done while protecting the starter gears. I have never seen a small, inexpensive preoiler pump advertised for our smaller engines. I remember seeing somewhere described an accumulator type system for engines that charged and trapped oil in an accumulator while the engine was running that could be then admitted to the system later for pre lube. Dont worry about that little chevy, she'll be fine--just turn the key, count to 20 and turn her loose.
Bob Taylor
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Amsoil builds a nice pre-oiler / accumulator. so does moroso and canton racing products. they are nice for starts after sitting for a long time, as well as for times when the oil pickup momentarily grabs air - really healthy small blocks in light vehicles or rock climbing
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I heard that the Japanese cars have something like this oiler. Is that true?
~Jim
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | none that I have ever wrenched on.
| | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | My VW bug (2001) has what I call a after oiler. Its some sort of pump the circulates oil after the engine is shut down. I believe they are cooling the turbo shaft. It wouldn't be hard to adapt to a old engine if you could get your hands on one.
Joe | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | most turbo motors have an electric circulating pump. VW even has a coolant circulating pump
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...if worried about cold start ups on a SBC with a carb then consider the following. I have two vehicles that may get started everyday but then they may set for weeks. So, after they have sat for a while I simply let the engine spin a few rounds till I see the oil pressure come up...which is pretty dang quick, THEN I pump the gas a time or two....besides, I wouldn't want to "wash" the cylinder walls with gas before they get oil. | | |
