| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | I have what I always thought was a 62' 235,but I'am having a hard time ordering a carb with a manual choke and throttle set up to run in a 51' GMC 3/4. I looked up the numbers,but would like a third party "some one with a bigger brain than mine" to varify. I'll start with the block. (Above the starter)#CON 3 D 24 2 . On the left side of the block # 21 716. Next "the head",Left side above the ports/ 3836848 GM 28. ON the right side is B 61 848/850,which should make it a 56'? Now for the "Intake" right side on top/# 8754644, on the left "15", 3" inch bolt spread,studs are in and out, "not" front to rear,with a 1"3/4 inch throat.I've been ordering replacement carbs by application with out any luck.Is this a car or truck engine? Oh! the exhast manifold # is 8885587/GM13. thanks in advance for any help or advice in getting this mess sorted out! Jimmy | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I looks like you do not have an original intake manifold. Can you post a link to a picture? B 61 848/850 does not designate anything helpful. You have a 56-63 235 head: 3836848 The block date code is for 1962: D 24 2 What is the engine ID serial number? http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Thanks for the "Pics" (Tclederman),and sorry for the waist of time by not giving you the number you needed most. Engine ID serial #3769716. I'll need A lot of help in the future to send "Pics",and my resident computer experts tell me, "It's not in my future unless I get a new computer"! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No problem, jimmy1,
3769716 is a bock casting code for a 58-63 block.
The engine serial number ID Is pressed into the block, to the rear of where the distributor enters the block. This should indicate the model truck the engine was first installed. The location of that code is shown in Photo 3.
Also, the block and head date casting codes would be interesting to see.
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Thanks!"We learn as we go",sorry for making it feel like your pulling teeth! Engine serial ID # FO6O6J.Block date? "location"! Head date? "Hope it's not under the valve cover"! jimmy | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The location of the head date casting code is under the valve cover.
You have already given the block date: D = April 24 = 24th 2 = 1962
F0606J F = Flint, MI 06 = April oops, June 06 = 6th J = Regular production truck engine (3100 - 3200 - 3800)
Maybe someone else will comment/correct/clarify the April 6th engine assembly date with an April 24th block casting date? ignored this - see correction, below - I have to learn to be more careful counting on my fingers
Last edited by tclederman; 07/30/2012 9:24 PM. Reason: Corrected month - see below
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | I was afraid you were going to say that,but I'am going to pull the cover tomorrow. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 0606 would be June 6th, not April.
Bill Burmeister | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Forgot to say "thanks", and all the carbs ordered have been auto 54' thru 62' applications. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |  Thanks, Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely an incorrect intake manifold. Someone might have changed it over the years, in order to install a different carburetor. What type of carburetor was on it?
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Pulled the cover, "left side" behind 2/3 ( CON9 ), behind 4/5 (F52). Don't feel bad about being a finger counter,I'am a wrench Fetcher and haven't been alowed at "Black Jack" in years! Math for me stops at 21, and they didn't see the humor in it. Thanks Jimmy | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Rochester 2 Jet on a adaptor spacer! A real "pig in a Poke",just bearly worked with lots of trouble! But it has a " manual" choke and throttle. | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | The intake has another #15 under the front intake tube. | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | The intake has another #15 under the front intake tube. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F52 F = 6th month = June 5 = 5th day 2 = 1962
One day before the assembly date? (check me on this)
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is there an adapter between the intake manifold and the Rochester 2-jet (2GC ?)? If not, someone might have adapted the manifold for the non-standard carburetor.
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Yes,there is an adapter,but its a after market. Is it safe to say the Head is original to the block? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Most likely an incorrect intake manifold. Someone might have changed it over the years, in order to install a different carburetor what is the carb stud spacing on the manifold? tclederman point may need to be addressed. | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | 3" inches ! what could it be off? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I believe the later 235 should have a carb spacing of 2 15/16. Corrections welcomed | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Not this, "intake" #8754644 3" center of stud to center of stud! It would be great to know what I have. jimmy | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | jimmy1,
If you mail me a photo, I'll host it and post it.
We are "flying blind" in trying to tell you what you have. You might have a GMC part or other part foreign to a 235.
