1 members (papas52), 139 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
So....if my turn signal switch burns out that would be indicative of a short or some kind of other electrical problem somewhere in that circuit, right?
I should probably try to get THAT problem solved before I install a new switch.....so I'm smart enough to figure that out on my own, I just don't where inthe heck to start.....
\m/
What year of truck are we talking about?
Joe
Turn signals meter out power to five places if you have a seven wire switch, Right front, left front, right rear, left rear and brake lights. Power comes into the switch and is dispersed to one of these places. Get under the dash and put your fingers on the wiring harness that comes from the switch. Chances are if the switch burned out, one or more of these wires will give you a clue as to where the problem lies. Wiring problems are not difficult if you look at the evidence and think them through..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
