| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87070 06/24/2003 3:09 PM | Joined: Jun 2003 Posts: 9 Member | | Member Joined: Jun 2003 Posts: 9 | So....if my turn signal switch burns out that would be indicative of a short or some kind of other electrical problem somewhere in that circuit, right?
I should probably try to get THAT problem solved before I install a new switch.....so I'm smart enough to figure that out on my own, I just don't where inthe heck to start.....
\m/
#87071 06/24/2003 3:38 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | What year of truck are we talking about?
Joe
#87072 06/24/2003 10:26 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Turn signals meter out power to five places if you have a seven wire switch, Right front, left front, right rear, left rear and brake lights. Power comes into the switch and is dispersed to one of these places. Get under the dash and put your fingers on the wiring harness that comes from the switch. Chances are if the switch burned out, one or more of these wires will give you a clue as to where the problem lies. Wiring problems are not difficult if you look at the evidence and think them through..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
