2 members (R&S 51 GMC, Tiny),
152
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | how do you adjust the rear shoes on a 1950 1/2 truck there are no holes in the backing plate or drums thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | leonard, sometimes the ones in the drums are hard to find so you can punch out the knock outs. Look close as sometimes the dirt and grease will hide the outline. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Has the rear axle housing been changed? Possible someone has put a later model housing with self-adjusting brakes? In most cases you can pull the drums off and knock out the hole for the adjuster opening. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | pulled the drums and the adjuster is made on the wheel cy found the knock out at the top of the backing plate on each side of the wheel cy now to get the brakes to bleed | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Got a pic? That don't sound right, adjusters on the wheel cylinder, but I'm not familar with all the rearends out there. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | here is a pic of that style on the front of my 50, Huck type ...pic...that's what he has on the rear | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | Is that the pre-bendix brake system?
1953 1 ton panel
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is that the pre-bendix brake system? yes According to the manual The bendix type started later Huck 48-50 48-51 on some big trucks, although I found bendix type on the rear of my 50. Changed over the years | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | that is the ones i have in the pic. now what is the best way to get the air out of the lines. i think i may have a bad master cy. new out of the box. can not get it to pump fluid to the wheel cy | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | Somebody on here told me 53 was the first year for the Bendix system. Maybe thats for 1 ton only?
1953 1 ton panel
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On 1/2 ton trucks, 1951 was the first years for factory Bendix style brakes on both front and rear (as shown in the Shop Manual in the link above).
| | | | | Joined: Jan 2011 Posts: 23 New Guy | | New Guy Joined: Jan 2011 Posts: 23 | I've just finished a conversion to front discs, with a dual master cylinder upgrade. Replaced all the brake lines and flex hoses, and replaced the huck rear wheel cylinders.
You want to make sure that you bench bleed the master cylinder, as an air pocket there can cause problems bleeding the system. Take a little time and adjust the wheel cylinders to get the brake shoes dialled-in.
I found it took a lot longer to get fluid to the rears than it did to the fronts, so patience will help as well. Make sure you've got the brake pedal travel sorted out at the master cylinder, so that you're moving enough fluid with each stroke. | | |
