7 members (Donf, Gdads51, cmayna, Otto Skorzeny, Forty9, Gray_Ghost, 1 invisible), 91 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
#870341 07/29/2012 11:57 AM
I have a '46 Chevy Panel that is going through a ground up resto/mod. There is no bed.
One of us wants to put a sheet metal floor in first, sound proof it with Dyno Mat and then sandwich wood strips over that.
I say go with wood floor only, and paint bottom with sound deadening paint or rhino shield it.
Is there a problem/advantage with doing either or something else we should really consider? What is wrong with putting a wood floor over a sheet metal one?
I'd guess that 3/4" wood is a better sound insulator than sheetmetal with dynamat. If you are planning on a thin wood veneer type finish then you would need the metal floor for strength.
1940 Chevy KC 1/2-Ton
Already have an oak floor for it - haven't installed it, trying to decide if it's worth putting in a metal floor first...One has the time, I just don't know if there is a reason not to. Thanks.
yes there is a reason not to, differential expansion/contraction of the different materials, you can't just have the wood floor 'float' on the metal like a faux-wood floor in a house, it needs to be firmly attached .... which leads to the certainty that sometime you'll see the effects of moisture/condensation between them, starting with rusting screws
I wouldn't be worried aobut the rust, but all hardware would need oval holes in the steel and loose enough that it could float. You're better off to just put your wood floor in without the metal underneath.
My 46 GMC on Photobucket
Thanks guys, we're skipping the metal floor idea..and sticking with the tried and true wood. Strangely I guess the engineers figured it long before what method works best. :-)
Anyone thought of just a steel floor - no wood? I am not a keener on originality but like practicality and it would put some weight in the otherwise light end.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Back in the 60's when we used the 54 truck to haul oak fire wood we had a 1/4" steel plate for the bed, very durable and strong... It set on top of the existing wood bed... Gave the truck good traction in the snow and mud... Downside is it is heavy...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
....I've seen LOTS of steel beds in my lifetime. Had a steel bed in my '50 and hauled anything! Not original but durable as all get out.
