3 members (Leo, Gdads51, 1 invisible), 171 guests, and 3 robots.
Topics128,088
Posts1,055,995
Members48,430
I have the nose off my 51 GMC again and about ready to reassemble, but noticed some stress cracks around alot of the bolt holes in the sheet metal.I was thinking of changing over to the flat ang spring washers.I'am not worried about keping it OEM at this point,but rather saveing the sheet metal,It's a driver. Any thoughts on this "Do or Don'ts" thanks
If the stress cracks are severe, perhaps a little mig welding is needed. If not, personally, I would use appropriate size flat washers.
Drew
Ex Hall Monitor
Ex Hall Monitor
Stop drill the cracks. If you don't they will continue to grow.
Star-type lock washers are good for electrical installations. The teeth dig into the paint a bit for better contact.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
If the metal around the holes are stressed, you might want to get flat washers too.
