1 members (Steelonsteel), 141 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#868090 07/20/2012 11:49 AM
I have a 1959 GMC 2 ton and was curious if the 5 speed trans in it would be the same used in a chevrolet of the same year?
Check for tags on the tranmission. I think GMC used several different tranmissions from Clark w/OD and straight drive and New Process if I'm thinking correctly.
So, it may or may not be.
Jeff
My 1953 Chevrolet
1947.1 Gallery
It is a NP540 DD..........will a chevy V8 bellhousing work on this......if so witch one?
Chevy and GMC used the same New Process 540 but I'm not sure which bell housing a Chev used.
I really depends on the application, they had a couple different size input shafts available, but the transmission bolt pattern was the same regardless which truck used them. Most of the ones that I have seen were the larger 1 1/2 inch dia shafts and will only work with the medium to heavy truck bell housings with the 13 inch clutch.
