3 members (baldeagle, Shade Baby, 1 invisible), 94 guests, and 4 robots.
Topics128,125
Posts1,056,336
Members48,439
#870349 07/29/2012 12:43 PM
how do you adjust the rear shoes on a 1950 1/2 truck there are no holes in the backing plate or drums thanks
leonard #870351 07/29/2012 12:49 PM
leonard, sometimes the ones in the drums are hard to find so you can punch out the knock outs. Look close as sometimes the dirt and grease will hide the outline.
leonard #870352 07/29/2012 12:51 PM
Y
Y Offline
Has the rear axle housing been changed? Possible someone has put a later model housing with self-adjusting brakes? In most cases you can pull the drums off and knock out the hole for the adjuster opening.
pulled the drums and the adjuster is made on the wheel cy found the knock out at the top of the backing plate on each side of the wheel cy now to get the brakes to bleed
leonard #870470 07/29/2012 9:28 PM
Y
Y Offline
Got a pic? That don't sound right, adjusters on the wheel cylinder, but I'm not familar with all the rearends out there.
here is a pic of that style on the front of my 50, Huck type
...pic...
that's what he has on the rear
DADS50 #870494 07/29/2012 10:10 PM
Is that the pre-bendix brake system?
1953 1 ton panel
yes
According to the manual The bendix type started later
Huck 48-50
48-51 on some big trucks,
although I found bendix type on the rear of my 50. Changed over the years
DADS50 #870566 07/30/2012 8:06 AM
that is the ones i have in the pic. now what is the best way to get the air out of the lines. i think i may have a bad master cy. new out of the box. can not get it to pump fluid to the wheel cy
leonard #870643 07/30/2012 2:07 PM
Somebody on here told me 53 was the first year for the Bendix system. Maybe thats for 1 ton only?
1953 1 ton panel
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0502.htm
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0503.htm
Im not sure when the bendix style came in. Above are pages from the manual.
did you bench bleed your M/C? you may have air trapped.
DADS50 #870655 07/30/2012 3:16 PM
On 1/2 ton trucks, 1951 was the first years for factory Bendix style brakes on both front and rear (as shown in the Shop Manual in the link above).
leonard #870687 07/30/2012 6:12 PM
I've just finished a conversion to front discs, with a dual master cylinder upgrade. Replaced all the brake lines and flex hoses, and replaced the huck rear wheel cylinders.
You want to make sure that you bench bleed the master cylinder, as an air pocket there can cause problems bleeding the system. Take a little time and adjust the wheel cylinders to get the brake shoes dialled-in.
I found it took a lot longer to get fluid to the rears than it did to the fronts, so patience will help as well. Make sure you've got the brake pedal travel sorted out at the master cylinder, so that you're moving enough fluid with each stroke.
Cheers,
Fraser
1950 Chevrolet 1300 1/2 ton (Built in Oshawa)
http://1950Chevy.blogspot.com
