1 members (pauld),
115
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I would like to apply decals on the tailgate letters over the base coat, can I apply the clear over the decals ? Also found out today there is a shelve life to primer hardeners, two weeks it said in the small print. To bad this error cost me a quart of primer. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Wow... two weeks? What brand are you using? Just so other know to avoid it, the brand I use (SPI) lasts a year.
| | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | PPG Shop Line. Any comments on clear coating over the decals? | | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | I see nobody has answered your question yet and neither can I. I put my decals on after the clear. Darren | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have cleared over decals several times. I like to do it that way, but, I have been told that the decals may lift. It always seems to be at your own risk, although I have not had a problem. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Yep you can clear over decals. The Indy car shops here in town use to do it all the time. Mainly for the Indy 500, to get that tenth of a second advantage over the other guy, now the big boys paint them on. The primer shelf life is after it is mixed with the hardener.
....David
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You could use an "inter coat" over the decals before clearing. That's what it's designed for I believe. Protecting art work layers.
