| | | Forums66 Topics128,100 Posts1,056,178 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 38 New Guy | | New Guy Joined: Dec 2009 Posts: 38 | Just wondering what everyone's using for truck covers. Good , better, best kind of thing. What should a guy expect to spend. thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year and model?
Custom fit (model specific) covers range in price from about $100-$800
Check Classic Parts of America and California Covers
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It's your choice, but personally I would only buy a truck cover as a dust,dirt protector not an outside all weather protector. They all seem to leak at some point and depending on the finish on your truck, could spot it terribly requiring a good cleaning and rewaxing. In one case on a sports car I had, the hood required repainting. That was after an expensive California Cover leaked at the seam. If you're allowed in your area, I would consider a portable outside tent garage as an option.
Drew
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I bought mine at Pep Boys for about $70. It's a cover and keeps the dust off.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Dec 2009 Posts: 38 New Guy | | New Guy Joined: Dec 2009 Posts: 38 | thanks guys, I have a 59apache short box fleetside. It has fresh paint and I plan to store it in my shop. My shop is anything but dust free so I plan to use the truck cover and then cover that with a loose tarp that I can take off and hose down once in a while. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I wouldn't recommend putting a tarp over the truck, even over the cover. The more weight you have on it will cause any little movement due to air to cause more damage and wear to the paint. I would think just a cover over the truck would be bets to keep the dust off. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A tarp will trap moisture. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I use old blankets and quilts. | | | | | Joined: Dec 2011 Posts: 32 New Guy | | New Guy Joined: Dec 2011 Posts: 32 | Wal-Mart has a cheap one that works good the only problem is the largest one is a little short around the doors. I can post some pictures if you want.
Larry | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | The wife sewed some old bed sheets together. They keep the dust off, and they're easy to wash and keep clean.
1939 Chevrolet Stake Truck
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Ditto the bed sheets. I have been using them for several years. I go to a second hand store (Salvation Army) and buy King size sheets and sew them together. Great inside storage protection. Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have found that the folks that do the most perfect fit are those that make boat covers. If you want to do a maximum job of protecting your truck it really needs a cover that fits tightly in order to eliminate as much dust etc. from under the cover.
~Jim
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Having been in the funeral business for a while I got a couple of velvet covers used to transport high end caskets from the manufacturer. One fits over the cab but does not go all the way down. Used indoors only. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If the purpose is to protect the paint etc. from bruises, I took two U-Hall blankets, cut them in half and had my wife to sew into two corners of each a 1.25" earth magnet. That way I can lay the blankets, one over each fender, and the magnets will hold them in place. I should add that this only works when the truck is not outside in the weather.
~Jim
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | THANKS FOR THE INFO.jUST WENT ON LINE LAST NIGHT FOR PRICES ETC.Flannel sheets sounds like a good idea. | | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | I had a Hugger cover made here in Ont. Called them up told them make and year , they asked if there was any thing to work around (hood ornament , mirrors etc.) made the cover and shipped it out . Fit like a glove . Family business that treats you right . I can't recall what it cost , that was 5 years ago. My truck sat in the shed here so keeping bird crap off it was the priority. when you come back from a car show it was easy to pull on. | | |
