0 members (), 114 guests, and 1 robot.
Topics128,105
Posts1,056,541
Members48,448
Id like to change from a floor starter to a key starter on my 1953 chevy 4100. It currently has a 6v system but Im going to convert to 12v. What do I need to add or replace?
you'll need a 6 volt starter for a key start vehicle. If you get a starter for a 12 volt vehicle you'll have a missmatch between starter and ring gear on flywheel. You'll need a starter switch designed for key start or a push button to power starter seleniod to engage starter. You may want to post this question in electrical bay also. you will have to run a hot wire from key switch to push button then to starter selenoid.
You shouldn't have a problem running a 6 volt starter with 12 volts. My family has done this for years on our Model T's with no problems. They will spin faster which is nice for starting a stubborn engine.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
The 6v starter will work just fine, a 12v much better, but you will need a 12v solenoid, or a voltage drop for a 6v solenoid after you convert to 12v. COE and automobiles used remote starters w/solenoids.
Are you planning on key start switch or a push bottom mounted on the dash?
As stated above to use a 12v starter you have to change the ring gear on the flywheel. I believe a 6v ring gear is 139 teeth and 12v ring gear is 168 teeth.
And if memory serves me correctly a 6v starter has a 10 teeth on the drive gear and a 12v has nine teeth.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
... thanks for asking this question, i would like to change mine too.
