| | | Forums66 Topics128,095 Posts1,056,492 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 9 New Guy | | New Guy Joined: Jun 2012 Posts: 9 | Id like to change from a floor starter to a key starter on my 1953 chevy 4100. It currently has a 6v system but Im going to convert to 12v. What do I need to add or replace? | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | you'll need a 6 volt starter for a key start vehicle. If you get a starter for a 12 volt vehicle you'll have a missmatch between starter and ring gear on flywheel. You'll need a starter switch designed for key start or a push button to power starter seleniod to engage starter. You may want to post this question in electrical bay also. you will have to run a hot wire from key switch to push button then to starter selenoid. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | You shouldn't have a problem running a 6 volt starter with 12 volts. My family has done this for years on our Model T's with no problems. They will spin faster which is nice for starting a stubborn engine. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | The 6v starter will work just fine, a 12v much better, but you will need a 12v solenoid, or a voltage drop for a 6v solenoid after you convert to 12v. COE and automobiles used remote starters w/solenoids.
Are you planning on key start switch or a push bottom mounted on the dash?
As stated above to use a 12v starter you have to change the ring gear on the flywheel. I believe a 6v ring gear is 139 teeth and 12v ring gear is 168 teeth.
And if memory serves me correctly a 6v starter has a 10 teeth on the drive gear and a 12v has nine teeth.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Feb 2011 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 32 | ... thanks for asking this question, i would like to change mine too. | | |
