| | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I've searched for Panel Interiors and came up short so I'm asking here...
I'm interested in hearing what you guys have done with your interiors - specifically the back end vs. cockpit. What did you do with the sides and roof?
Thanks! | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | Well, mine has a lovely 70's orange shag carpet in the front with a crumbling vintage aftermarket steering wheel, random gauges everywhere, modified overhead console from a '39 Mack truck, torn mystery bucket seats, no head liner throughout, original wood floor in the back and a few peices of cardboard shoved in the sides to keep the panel sides from shaking over bumps. Hope that helps give you some ideas! hahaha.
1953 1 ton panel
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Great image! Especially the orange shag carpet!
I'm looking to go in a different direction than carpeting and paneling - - anyone else out there care to share what you've done (and photos?) Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bartamos came up with a good rear headliner idea, although it works best with the scarce metal valances that the panels don't have in the back - for the cargo area sides, I've always put thin painted wood paneling between the uprights with the foil/bubble insulation glued to the back, leaving the cargo tiedown wood strip, which is oak and looks nice with a good clear finish Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I glued grey vinyl to very thin plywood (door skin material, about 1/16" thick) and did the upper part of the sides. On the floor I put thin rubber right over the original wood floor. The ceiling has plastic bubble wrap as an insulation, still wondering about the ceiling liner. The cab floor has an original style rubber mat. I haul lumber to job sites with mine so shag wouldn't work. I hope shag carpet never makes a comeback. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | "bubble wrap" overhead and inbetween "posts". Front floor will be the orignal type felt and rubber.
Lucky for me when I retired the company was making automotive fabric for OEM's including the headliner material laminated to the thin foam. Soooo, I have enough of the headliner to use in my panel...AND I have a big roll of grey fabric that was the very FIRST roll to come off the machines for about 3 or the OEM models that were to be 2006. That roll of fabric will be the side panels to match a set of lt grey bucket seats out of 99-06 GM models. Oh, the overhead is a light grey to like what is probably in most of your cars and trucks....for the rear plywood floor I'm not sure but thinking a thin layer of low pile commercial grade carpet...we'll see...and a 58 Impala steering wheel. | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Great ideas guys! Any more out there?? | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | On my 49 burb I have carpet in the rear floor that can be taken out if necessary to haul STUFF. I am in process of making cloth covered panels with MDF for the sides that can also be removed when needed. I hope to complete over the weeknd and will post if successful.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | For my Suburban, I'm going to do a stained wood floor in the cab section. Some day it will all get torn out to replace the rust and holes, but I couldn't beat $20 for a left over box from a job done by a local flooring company. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | | | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | you've got more work space in there then my garage!
1953 1 ton panel
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Well so far, I've stripped the layers of paint off of the wood floor, stained it with a semi-transparent stain... Put a layer of Peel 'n Seal on the ceiling and wall panels... Added a layer of foundation styrofoam insulation on the walls; then put a layer of jute carpet padding on walls and ceiling. I'm planning on finishing off upper walls and ceiling by running 1x2 wood strips length wise with 1/4" between them.
The Project continues! | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | It was great getting all of the feedback about what to do with the panel rear interior. Here's what I ended up doing... 1) Striped the wood floor and stained & poly'd it 2) Put Peel 'n Seal throughout interior - side walls, roof, under dash, on front floor... even put strips in side walls through access panels. 3) Glued styro panels (the house foundation type) over Peel 'n Seal on side walls 4) Glued jute carpet padding over styro and over entire interior roof and front floor and under dash 5) Screwed 1x3 stained poplar strips along side walls and across ceiling. Overall I'm really pleased with how it came out. Pics heah: http://fernscountrystore.com/fun/ferns-fotos/bella-the-ferns-wondertruck/?nggpage=2 | | | | | Joined: Oct 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 62 | :thumbs_up:
Keep the pics coming :pix:
Don J :wave: | | | | | Joined: Jan 2011 Posts: 35 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 35 | The sides and top look like a million bux! Very well done!
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | | | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | PEP Boys (check on line) used to carry fabric on foam cloth in many different colors. It's marketed as replacement headliner cloth for late model cars and trucks.
1999 GMC Yukon 1957 GMC 100 Panel
