2 members (cmayna, Wickedbass),
71
Mod | | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Hello, This may be a pretty straight forward question here on a conversion of 6V to 12Volt systems. I have a 6Volt ignition switch....when I change over to 12 volt do I need to replace the ignation switch as well? To a 12... Thanks! John | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | ..when I change over to 12 volt do I need to replace the ignation switch as well? To a 12... Nope, it doesn't care what voltage you have.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Change the #51 6v bulb in the ign switch to #53 12v bulb. Is your truck a '54? Here are the equivalent 12v bulbs for the 6v bulbs in your dash ... < CLICK >I omitted the 12v bulb for the accessory cigarette lighter. It is probably #53.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 38 | Thanks for the clearification on my needing to change out the switch also thanks Lonnie for the lamp reference table. Good work. Best, john | | |
