1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
Hello,
This may be a pretty straight forward question here on a conversion of 6V to 12Volt systems. I have a 6Volt ignition switch....when I change over to 12 volt do I need to replace the ignation switch as well? To a 12...
Thanks!
Ex Hall Monitor
Ex Hall Monitor
Nope, it doesn't care what voltage you have.
Change the #51 6v bulb in the ign switch to #53 12v bulb.
Is your truck a '54? Here are the equivalent 12v bulbs for the 6v bulbs in your dash ...
< CLICK >
I omitted the 12v bulb for the accessory cigarette lighter. It is probably #53.
- Lonnie
My '54 3104
Thanks for the clearification on my needing to change out the switch also thanks Lonnie for the lamp reference table. Good work.
Best,
john
