3 members (Otto Skorzeny, 55shaker, ronsway), 71 guests, and 3 robots.
Topics128,077
Posts1,056,019
Members48,433
I thought my engine was a 1953 chevy 216 but later found out it was a 1957-62 chevy 235 after I bought the new starter. I took the starter off and went to napa and the new starter I got looked like the same one I took off the engine. I put the new one on and now it could engage every time. It sounds like the starter just spins without turning the fly wheel. It does engages once in a while. We tried to it the starter without pressing down the starter pedal and it just sounds like it spins. Can you run a starter for a 216 on a 235?
Don't think so...The 216 wouuld be a 6 volt system and the "55 and up would be a 12 volt..the flywheel teeth are a different count and pitch....plus the starter drive shaft dimmention is different...You'll need to take the 216 starter back and get one for whatever 235 engine you have...
