0 members (), 88 guests, and 3 robots.
Topics128,143
Posts1,056,494
Members48,442
#868619 07/22/2012 6:14 PM
Hi, I recently purchased a new bed fabricated to match the original look but including a steel deck. All made from 3mm steel.Because of the strength of the bed there are no cross bearers running across the width of the tray.
I have looked at the bed mounting blocks available but they are all too small and must take account of Cross bearers running the width of the tray of the original
Does any one have the measurements between the chassis and the actual deck
Seems to be about 5 1/2 inches at front and 3 1/4 inches at rear
you might find good info here ... if you have the cross sills from the original bed it'd be a good idea to use them, if not maybe you could fab some up, they do serve a purpose
Going from memory on my '40, blocks were 2 1/4" high, plus the 3/4" thickness of the wood planks making about 3" overall. Not sure that even with 3 mm steel the bed won't deflect ?
1940 Chevy KC 1/2-Ton
Bruce is correct with the 2 1/4" blocks ect. Same on my 37
Thanks for replys - As I dont have cross sills on my bed could any one advise the depth of these
Here is a shot of my cross sill but I don't have the measurements.
Also, you may want to think about putting a samll "cushion" under the bed blocks to help eliminate any squeaks ect.
http://i140.photobucket.com/albums/r19/LutherParris/Nexttorear.jpg
I'm not saying mine is prefect. Back when I did my bed I had nothing to go on so I did what I had to do. Maybe this will give you an idea of what it looks like.
