Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (GMCJammer51, Hotrod Lincoln, Otto Skorzeny, IHPWR, DJHobbit'46Chevy, 1 invisible), 558 guests, and 1 robot.
Topics126,780
Posts1,039,296
Members48,100
Most Online2,175
Jul 21st, 2025
#868550 07/22/2012 1:35 PM
What type of hardware is used at this pivot point?? Shouldered bolt? Pivot tube? See picture.
http://www.bunchobikes.com/jumpseat.jpg
Mine had a barrel spacer between the brackets and a through bolt attached with an acorn nut.
Thanks George. From the size of the holes and shapes of the brackets, that's what I was thinking. Especially since the rest of the pivot points use barrel spacers.
Weeds,
I got those. It's where the seat bottom and the seat back connect that I'm concerned about.
a standard bolt and an acorn nut facing outward towards the passenger door if I recall
There is a bolt and a short metal sleeve and a acorn nut.
Tim
1951 3100 Chevrolet
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.369s Queries: 14 (0.048s) Memory: 0.6196 MB (Peak: 0.6902 MB) Data Comp: Zlib Server Time: 2025-09-22 20:49:23 UTC
Valid HTML 5 and Valid CSS
