4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
#868550 07/22/2012 1:35 PM
What type of hardware is used at this pivot point?? Shouldered bolt? Pivot tube? See picture.
http://www.bunchobikes.com/jumpseat.jpg
Mine had a barrel spacer between the brackets and a through bolt attached with an acorn nut.
Thanks George. From the size of the holes and shapes of the brackets, that's what I was thinking. Especially since the rest of the pivot points use barrel spacers.
Weeds,
I got those. It's where the seat bottom and the seat back connect that I'm concerned about.
a standard bolt and an acorn nut facing outward towards the passenger door if I recall
There is a bolt and a short metal sleeve and a acorn nut.
Tim
1951 3100 Chevrolet
