| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86832 02/13/2002 4:12 AM | Joined: Jan 2002 Posts: 72 Member | | Member Joined: Jan 2002 Posts: 72 | are the ad trucks wipers only operating on vacuum??? :confused:
49' Chev, 3808 platform
#86833 02/13/2002 4:19 AM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Yep. There are kits however that u can get that convert to electric motors. LMC Truck, Brothers, etc.
Buzz'n Half Dozen
#86834 02/13/2002 4:20 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Originally yes they were only vacuum, but you can buy aftermarket electric wiper motors for your truck.  | | |
#86835 02/13/2002 5:27 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thadley & Others,
In 1954/55 there was a factory option, two-speed wiper. It is rare but Golden State Pickup seems to be able to find them.
If you plan on using the original radio in a '54, the aftermarket electric wipers will not fit (this is only a problem in a '54 and with a '54 radio and a non-factory electric wiper).
Tim | | |
#86836 02/14/2002 10:26 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | My 52 GMC 470 big truck has an air pressure wiper!  Course it has an air pump and air brakes too!  First time I'ld ever seen one.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#86837 02/15/2002 2:34 PM | Joined: Jan 2002 Posts: 72 Member | | Member Joined: Jan 2002 Posts: 72 | I got vaccuum to the wiper mechanism and the switch on the dash pivots, howevever no action. Are these devices repairable? What can I look for as the culprit or cause of failure??
#86838 02/15/2002 4:07 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Thadley, My vacumn motor leaks and is not running very well. I'm going to send it in for a total rebuild by "wiperman.com". Check out their site. I've heard that when the motors are overhauled they work fantastically.
Depending on what year, the cost is from $59 to $69 and comes with a 3 year warranty.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#86839 02/15/2002 7:55 PM | Joined: Oct 2001 Posts: 54 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 54 | MR PERRY YOUR 52 GMC 470 big truck HAS A AIR PRESSURE WIPER, BY CHANCE WOULD IT HAVVE BEEN MANUFACTURED BY AIR SPRAGUE COMPANY. OUR TROLLEY CARS SOMTIMES ARE OUTFITTED WITH AIR SPRAGUE WIPER MOTORS.
Yes, officer it's licensed.
#86840 02/15/2002 10:06 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Yes, they are repairable. There is a diaphragm inside that probably needs replaced. I don't recall who sells them, but go to the links section and look.
Fred 52 3600 69 C-10
#86841 02/16/2002 1:14 AM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | Check to make sure the rod connecting the wiper switch to the motor is installed. It is about 2-3 inches long, with a bend at each end. Either end can come loose if you've been working up under the dash. The diaphragms inside the motor dry out. SOme can be restored with petroleum jelly or with a new piece of leather and I think there are some old threads on fixing the motors in the archives on this site. | | |
#86842 02/16/2002 4:12 AM | Joined: Jan 2002 Posts: 72 Member | | Member Joined: Jan 2002 Posts: 72 | I'm always amazed at how all of this works "this techy stuff" with this forum and all .... but boy am I glad that I'm able to peck my way into this cyberspace, wherever that is? :confused: The info available with all of this is a really special and trully intimidating to someone like me who at times feels like I'm from the previous generation.......but it is all GOOOOD!
#86843 02/16/2002 3:39 PM | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | I carefully took mine apart, cleaned and then regreased the flapper. Here's the Wiperman site, looks to be the way I'll go. http://www.wiperman.com/
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#86844 02/17/2002 1:27 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i KNOW every thing i need to fix up my rides is on the net if i can only find it. | | |
#86845 02/17/2002 2:32 AM | Joined: Jan 2002 Posts: 72 Member | | Member Joined: Jan 2002 Posts: 72 | zenish, this is certainly the place to be for the inline sixes, namely the "Ol' Stovebolt". and I say that with admiration and experience..
