3 members (Jon G, Guitplayer, Wally / Montana), 123 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#86832 02/13/2002 4:12 AM
are the ad trucks wipers only operating on vacuum??? :confused:
49' Chev, 3808 platform
Yep. There are kits however that u can get that convert to electric motors. LMC Truck, Brothers, etc.
Buzz'n Half Dozen
Originally yes they were only vacuum, but you can buy aftermarket electric wiper motors for your truck. smile
Thadley & Others,
In 1954/55 there was a factory option, two-speed wiper. It is rare but Golden State Pickup seems to be able to find them.
If you plan on using the original radio in a '54, the aftermarket electric wipers will not fit (this is only a problem in a '54 and with a '54 radio and a non-factory electric wiper).
Tim
#86836 02/14/2002 10:26 AM
My 52 GMC 470 big truck has an air pressure wiper! grin Course it has an air pump and air brakes too! cool First time I'ld ever seen one.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
I got vaccuum to the wiper mechanism and the switch on the dash pivots, howevever no action. Are these devices repairable? What can I look for as the culprit or cause of failure??
Thadley,
My vacumn motor leaks and is not running very well. I'm going to send it in for a total rebuild by "wiperman.com". Check out their site. I've heard that when the motors are overhauled they work fantastically.
Depending on what year, the cost is from $59 to $69 and comes with a 3 year warranty.
Craig
MR PERRY YOUR 52 GMC 470 big truck HAS A AIR PRESSURE WIPER, BY CHANCE WOULD IT HAVVE BEEN MANUFACTURED BY AIR SPRAGUE COMPANY. OUR TROLLEY CARS SOMTIMES ARE OUTFITTED WITH AIR SPRAGUE WIPER MOTORS.
Yes, officer it's licensed.
#86840 02/15/2002 10:06 PM
Yes, they are repairable. There is a diaphragm inside that probably needs replaced. I don't recall who sells them, but go to the links section and look.
Fred
52 3600
69 C-10
Check to make sure the rod connecting the wiper switch to the motor is installed. It is about 2-3 inches long, with a bend at each end. Either end can come loose if you've been working up under the dash. The diaphragms inside the motor dry out. SOme can be restored with petroleum jelly or with a new piece of leather and I think there are some old threads on fixing the motors in the archives on this site.
I'm always amazed at how all of this works "this techy stuff" with this forum and all .... but boy am I glad that I'm able to peck my way into this cyberspace, wherever that is? :confused: The info available with all of this is a really special and trully intimidating to someone like me who at times feels like I'm from the previous generation.......but it is all GOOOOD! grin
ODSS President
ODSS President
I carefully took mine apart, cleaned and then regreased the flapper. Here's the Wiperman site, looks to be the way I'll go. http://www.wiperman.com/
~ Cosmo
1949 Chevy Half Ton
Z
Z Offline
i KNOW every thing i need to fix up my rides is on the net if i can only find it.
zenish, this is certainly the place to be for the inline sixes, namely the "Ol' Stovebolt". and I say that with admiration and experience.. wink
