3 members (Achipmunk, Leo, Phak1), 93 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
Does anyone sell just the fill plug? Mines been busted off and I'm rebuilding this master, depending on how it looks inside.
1953 1 ton panel
nevermind! found one that should work.
1953 1 ton panel
How many people are still running the factory original?
http://good-times.webshots.com/photo/2227488090102454676VmRXro
Mine is the same one as yours, except in worse shape. I could barely make out the words and the hex is busted off leaving a large hole in the top, which had a carved down broom handle end stuck in it.
1953 1 ton panel
Mine is original, and about the same shape as yours.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
I've had a number or originals on 55-59's - problem with them is they corrode solid to the MC - a good practice if you want to keep an original is to source a large O-ring that will fit the cap as a gasket to keep it from seizing on - otherwise many vendors have plastic caps and a few have aluminum
When I pulled mine off it had a paper gasket. I'm sure it would have been seized if it didn't.
1953 1 ton panel
and the paper gasket got put on after the PO broke the hex off getting it open grin
Hahaha, right!?
1953 1 ton panel
