8 members (Hanks custodian, FAST55, Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L.), 82 guests, and 3 robots.
Topics128,075
Posts1,056,003
Members48,433
#676923 09/10/2010 9:57 PM
Does anyone have one of these installed on their stovebolt? It mounts directly to the block replacing the oil distributor valve cover. Looking for positive/negative comments on how it has held up under actual use. Thanks.
Ed
Apprentice
Apprentice
Ithink that is what I may have does it look like this
http://i245.photobucket.com/albums/gg59/cobraosc/1950%20Chevy%203604/SANY0067.jpg
http://i245.photobucket.com/albums/gg59/cobraosc/1950%20Chevy%203604/SANY0063.jpg
Unfortunately I never got to see my engine in one piece so I couldnt comment on how it works. Do you have any pics of yours installed? Thanks
Never heard anything bad about them. I know a few guys that are running them. They don’t seem to have any trouble finding replacement cartridges at the local FLAPS. Eliminating the hoses and a direct route for the oil flow to the filter makes more sense to me. It’s easier to change the filter and clean the canister because the horn and fuel lines aren’t in the way. I’d like to find one for my truck but haven’t had any luck.
That said, if one is restoring for points then it’s incorrect and not a suitable stand-in for the AC accessory filter.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks Denny, Think I'll go for it and install it. Other opinions I've got say they're solid & reliable. Mostly used on cars I believe.
Ed
Came across this in a search and I thought I'd add some part numbers for those using the block mounted InnerLine "Filtor"
NAPA part numbers for the InnerLine Filtor:
Gasket: 5062
(from #1080 NAPA Gold Filter)
Filter: 1010
Forty9, are you sure the link is good? Not working for me.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
