| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Does anyone have one of these installed on their stovebolt? It mounts directly to the block replacing the oil distributor valve cover. Looking for positive/negative comments on how it has held up under actual use. Thanks.
Ed
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Never heard anything bad about them. I know a few guys that are running them. They don’t seem to have any trouble finding replacement cartridges at the local FLAPS. Eliminating the hoses and a direct route for the oil flow to the filter makes more sense to me. It’s easier to change the filter and clean the canister because the horn and fuel lines aren’t in the way. I’d like to find one for my truck but haven’t had any luck. That said, if one is restoring for points then it’s incorrect and not a suitable stand-in for the AC accessory filter. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Thanks Denny, Think I'll go for it and install it. Other opinions I've got say they're solid & reliable. Mostly used on cars I believe.
Ed
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Came across this in a search and I thought I'd add some part numbers for those using the block mounted InnerLine "Filtor"
NAPA part numbers for the InnerLine Filtor: Gasket: 5062 (from #1080 NAPA Gold Filter) Filter: 1010
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Forty9, are you sure the link is good? Not working for me. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
