1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#867421 07/17/2012 2:46 PM
I was wondering what modifications had to happen to put a 305 engine in a 1949 Chevy 3100
Or a GM 327
All the small block chevy's will have basically the same situations. In reality its not that big of a deal. I opted for the motor mounts that fit in the chassis rail. Then a cross member for the back of the tranny.....but I don't mean to "make light" of the conversion but its not that bad. My 305 fits nicely in my 52 panel and I did not have to alter the firewall. Some of what you need to do depends on what kind of front end set up you chose to go with. LOTS of us guys have done this modification so there is plenty of help around.
Feel free to browse my photobucket and you may something that will help.
Probably the biggest issue will be the steering gear, as it will interfere with the left side exhaust manifold. Some guys moove the box over, some offset the engine. I have heard the the '55-'59 box bolts up in the stock location and clears, but I can't confirm that.
Bill Burmeister
