| | | Forums66 Topics128,113 Posts1,056,614 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Hello,
Well, last Wednesday my 1941 g506 military 4x4 finally made it's journey from the desert region of Utah. I have spent the last couple of days inspecting my "new find". Since the truck is relatively complete with the exception of a small block engine and SM420, I am planning on restoration. The only exception is that I will be installing a 1954 235.
Here is the question. Who does reliable sand blasting and engine machine work in the Asheville, NC vicinity? I have heard good and bad stories about some machine shops in Asheville and wonder if I should travel farther away for this work. Someone with experience with 235's would be a plus. As for the sandblasting, I have come up with a big zero. None in the phonebook and no good leads.
Your collective advise is needed.
ps I have been too busy cleaning and wrenching to bother much with posting items, so no pictures yet. What is the process for image posting?
Paul | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 |
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, there ia a guy in Forrest City which is not to far from you that will come to your house and do the blasting. Early summer he came to my neighbor's house and blasted his 50 GMC. Everything was in pieces except the cab was still on the chassis. This guy has done it for many years and has a big rig set up on the back of his truck and a pallet of sand!!
I'll get his name and number and get back to you. Alvin | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | David and Alvin,
Thanks for the information, and I would like to get the number for the guy in Forest City. How did he recover all of the sand/paint? I think I would rather bring it to him.
Any reputable engine rebuilders?
Will try to make time for photos.
Paul | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, I sent James an email for the guys number and he said he'd find it for me so sit tight for a day.
Actually, he did NOT recover any of the sand. Believe it or not there was a good breeze blowing that day so there was very little on the ground. No complaints from anyone as it was blowing to the back of his property. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks,
I am not ready right now, just planning. My wallet needs to recover from the transporter shock first.
Want to develop a "source list" of machinists and metal workers.
Paul | | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | hey Paul, I live here in Asheville. I have run into the same issue with finding engine work, but One of my father's oldest has a sandblasting business I'll get his number and message you. At the very least it would be a local option. I've been contemplating doing the same. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | shakey73,
Where did you go for machinist work? I have good and bad about Ingrams. I spoke with them, they said they rebuild 2-3 235's a year. Shop was kind of messy and unorganized. Still searching.
Look forward to the sandblasting source.
What kind of truck do you own?
Paul | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Paul, You might want to consider soda blasting rather than sand blasting. Much easier on the metal and no loose silica dust floating around. I know there are some good soda blasters in NC who specialize in automobiles. They will come to you, or you go to them. The only thing is, you will need to paint it immediately after blasting. I'm NOT endorsing the folks at the link below, just found 'em on google so you have a place to start researching. lake norman soda blasting Good luck! Kurt | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...don't give up on me Paul. My neighbor can't find the guys name but I know a body shop that he does work for and can check there....maybe tomorrow. Sorry for inconviencing you. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks guys, no worry about the time lag as I stated before I am in the planning stage now. I am happily spending all of my money on brakes and axle seals right now. Want to make this truck stop before I start!
Would like to see what is out there in my "universe".
I still have not gotten any positive feedback on reputable engine rebuilders. Is there anyone out there?
Paul | | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | hey Paul, I haven't had any machining work done just mechanical work that is over my head. I've got a 52 3100 with a 235 and 4 speed. Also called our family friend who does blasting and kinda filled him in that you were in the planning stage. He said he would be glad to talk to about what you need when you're ready. Anyway I'm sending you a PM with his information. Hope it helps. | | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Paul, I bought a 235 from a guy back in 2005 from Huntersville N.C outside Charlotte. He specialized in 235-236 ci engines. If you are interested let me know and I will get you his name and telephone number. He rebuilt, repaired both stock and modified engines. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | cvett,
I have heard rumor about the guy in Huntersville. Would be worth a phone call. I have a sister down near there, would give me a good reason to pay a visit. Contact information would be appreciated.
Paul
| | | | | Joined: Mar 2005 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 89 | Paul, His name is Troy Robertson and the number I had was 704-875-2783. As I said I bought my 235 back in 2005 so I don't know if he is still in business or not but doesn't hurt to give it a try. | | | | | Joined: Jun 2005 Posts: 8 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 8 | Paul, Troy Robertson is well known in the "Inliners International" community. There are a few members in your area that may be able to help U locally. I haven't been a member in a while so these guys may not be active or available.
Buddy Boone, Waynesville, 828-452-5562 - Brian Holan, Tryon, 828-859-9955 - Buddy Tallant, Ashville, 828-251-0333.
Charlotte Auto Fair is coming up and I believe Troy Robertson sets up in the Green Field and usually has a running engine on a stand as well as in line parts.
Good luck.
'55 1st series, '67 CST, '93 Sport Truck.
| | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | hey Paul, just offering two hands if you need them at all. I look for any opportunity to learn and get experience. I can turn a wrench and follow directions pretty well. Anyway if you need any help just message me I can send you my number. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Thanks guys, great leads! I will interview them and see how it goes. I am not familiar with "inliners international". I would feel better having someone familiar with stovebolts do the job. Seems that machinists are a dying breed. "Having" to go to the Charlotte swap meet isn't such a bad thing. | | | | | Joined: Jan 2012 Posts: 17 New Guy | | New Guy Joined: Jan 2012 Posts: 17 | Inliners is another forum like ours. I found Stovebolt on a thread on they're forum. I think they talk about all old inline sixes. A guy led me inliners.com when I was researching my engine.
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Kurt, about your soda blasting comment, I was talking to a paint and body guy today who said he won't do soda blasting again, as he has had problems with the soda remaining in cracks and crevices, and eventually bleeding into the paint or filler, and causing bubbling! No personal experience here, just wanted to pass along his comments. Had not heard about this before.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...its been stated here sometime ago that some companies will not guarantee paint that is painted where soda has been used...... | | |
