2 members (DIY.MechanicMike, Stovebolt48), 76 guests, and 3 robots.
Topics128,179
Posts1,057,064
Members48,460
Hi folks,
Well, I'm well into my 1964 Chevy C60 disassembly and I'm thinking ahead a little. The wiring harness on the truck is pretty lousy as it has been cut, spiced into, etc. I have numerous catalogs from restoration parts sites and have seen wiring harness assemblies, headlight wiring assemblies, etc. available for sale.
Will these work for my C60? My truck has a 292 CID, standard heating system, standard lights, dash with all guages (no tachometer), etc. I see no reason why these won't work for me but figured I'd post and see if anyone has ever used the reproduction harnesses??
Any inputs would be appreciated...
Burgie
1964 Chevy C60 w/ Garwood dump, 327 CID, New Process 540C 5-Speed w/ Chevy 15,000 lb. 2-speed rear axle
1966 Chevy C60 w/ 292 CID, Chevy 4-speed w/ Chevy 15,000 lb. single speed rear axle
[b]Burgie's 1964 Chevy C60 Restoration Site[/b]
Riding in the Passing Lane
The 6 cyl wires to the engine will be different
from an 8. Check what alt/gen. you are useing
& try to get a harness to match or you will
have to modify it. smile
1972 Chevy c10 Cheyenne Super
Wrenchbender,
Thanks for the response.
What I am seeking, however, is feedback from someone who may have purchased a wiring harness for their truck. Did it work? How was the quality? Wire lengths correct? Provided the correct one was ordered, were any modifications necessary? Etc...
Thanks, in advance!!
Burgie
Here's what I did with my 54:
Click Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
I followed Horvath's advice and went with a 21 circuit harness for my 55.1
I pulled out the wires I didn't need and it turned out to be a great investment $180.00 I believe for the harness. A slow process but well worth it.
EZ Wire Harness was the outfit, I called and talked to them they were very helpful.
Chris
Chris 1955FirstSeries
Junior Member
Junior Member
I updated both my 64 Chevy suburban and my 65 GMC pickup with with modern SI-10 alternator, HEI, and Halogen headlights on relays... Most of the OEM wiring was marginal, at best, so I went for a PAINLESS wiring 18 circuit harness for the suburban... took an entire weekend, I work real slow and carefully, I detest doing things twice... and I have the circuits needed for all power accessories, should I wish to add... the wiring is top-notch, 600 volts capacity, all labeled and the tech support was real good and fast, for the few questions I had... A little expensive, but it looks better than factory, and so far reliable...
Good luck!
Pete in NE PA
1964 Cheverolet Carryall
1965 GMC 1/2 ton
