| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86653 09/12/2004 6:05 PM | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Hi folks, Well, I'm well into my 1964 Chevy C60 disassembly and I'm thinking ahead a little. The wiring harness on the truck is pretty lousy as it has been cut, spiced into, etc. I have numerous catalogs from restoration parts sites and have seen wiring harness assemblies, headlight wiring assemblies, etc. available for sale. Will these work for my C60? My truck has a 292 CID, standard heating system, standard lights, dash with all guages (no tachometer), etc. I see no reason why these won't work for me but figured I'd post and see if anyone has ever used the reproduction harnesses?? Any inputs would be appreciated... | | |
#86654 09/12/2004 9:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The 6 cyl wires to the engine will be different from an 8. Check what alt/gen. you are useing & try to get a harness to match or you will have to modify it.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#86655 09/14/2004 7:16 PM | Joined: Dec 2001 Posts: 187 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 187 | Wrenchbender,
Thanks for the response.
What I am seeking, however, is feedback from someone who may have purchased a wiring harness for their truck. Did it work? How was the quality? Wire lengths correct? Provided the correct one was ordered, were any modifications necessary? Etc...
Thanks, in advance!! | | |
#86656 09/15/2004 6:13 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Here's what I did with my 54: Click Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#86657 09/15/2004 7:21 PM | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I followed Horvath's advice and went with a 21 circuit harness for my 55.1
I pulled out the wires I didn't need and it turned out to be a great investment $180.00 I believe for the harness. A slow process but well worth it.
EZ Wire Harness was the outfit, I called and talked to them they were very helpful.
Chris
Chris 1955FirstSeries
#86658 09/20/2004 11:28 AM | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | I updated both my 64 Chevy suburban and my 65 GMC pickup with with modern SI-10 alternator, HEI, and Halogen headlights on relays... Most of the OEM wiring was marginal, at best, so I went for a PAINLESS wiring 18 circuit harness for the suburban... took an entire weekend, I work real slow and carefully, I detest doing things twice... and I have the circuits needed for all power accessories, should I wish to add... the wiring is top-notch, 600 volts capacity, all labeled and the tech support was real good and fast, for the few questions I had... A little expensive, but it looks better than factory, and so far reliable... Good luck!
Pete in NE PA 1964 Cheverolet Carryall 1965 GMC 1/2 ton
