10 members (Scott, 48jim1ton, frogfarmer, Wayne67vert, cmayna, Wally / Montana, gswbbc, Gdads51, panel fan, FAST55),
121
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | So, where do I start............no, really, where do I start?
As some may have read in previous posts, I have a '49 short bed half ton that came to me with a "modern" engine/transmission, Camaro front end and a Nova rear end. Apparently it was a popular conversion a number of years ago. In any event, the truck also included a "modern" wiring harness.
Ever since I got the truck, I have been cutting unnecessary wiring our of the harness. I have kept the original GM fuse block, the steering column switches, and the aftermarket gauges. Most everything else has been cut out or cut back. I have left pigtails on most circuits in case I need to revive them for some reason. Now comes the moment of truth........
It's time to start the rewire process. I want to use my GM fuse block, and most likely will have to run new wires from the fuse block to the termination end. I have identified 23 things I will have in the truck that will require electrical service to operate. The problem is, I have no idea how to go about consolidating circuits, or just about anything else regarding the rewiring the entire truck.
I have looked online, but there are only a few very limited resources about "How To" go about doing this. I can't justify the expense of buying a pre-made harness that would include all the things I think I will need. I just want to run some wires, and have it all work.
Does anyone know of or have a book on how to go about this process, step-by-step? Maybe a really good website? Some good clues? Anyone ever done this?
Help me Obi-Wan! | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | have used this book numerous times . it assists me when working on hot rods over here in OZ with US made equipment i.e tilt columns etc. simple easy to understand and cheap
http://www.speedwaymotors.com/Book-How-To-Wire-Your-Street-Rod,2824.html
regards andrew | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Let's see if I understand this.
1. Someone put a used harness in the truck.
2. You have been cutting wires out of it without knowing what they went to.
3. You want to rewire 23 circuits.
4. You have never done any automotive wiring before.
5. You think a booklet will help you get through it.
If all the above is correct, I think you have a potential fire hazard in the making, not to mention the problems you'll have trouble shooting before the fire.
My advice is buy a harness. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Andrew, dont know if I have mentioned this before but you have one great looking truck Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Hey Andrew, thanks for the vote of confidence. I have seen that book advertised but no one to recommend it. I'll check it out. | | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Great follow up information as well Andrew. You listed some sites I hadn't seen before from my searches. I've added them to my "Truck Favorites". Exactly what I was after! Now gotta get to work! | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Sounds like a total rewire is in order and with a quality aftermarket harness. Personally, I like Painless products. They sell a GM style harness that is specifically for a truck.
I've installed, 4 of these and it is a rewarding project when finished.
WHat ever you use ....GROUND .... Ground ....Ground! Battery to engine.... engine to frame .... frame to body .... etc etc Also, take note of MadElectrical above..... They speak the truth on "one wire" alternator setups vs. stock....
my 2 cents
mike
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I'd have to agree with the previous posters who suggest a new harness. You can pick up one on E Bay for a few hundred dollars or less if you are lucky. Get one with lots of circuits, tear out what remains of the old harness, and start fresh. You get a complete kit with instructions and tech help line if you get stuck. Wires are correctly color coded / labelled, and guages are correct. In my case, I used a Painless Universal truck harness which is GM color coded, and had ample ciruits for what I needed, plus a few extra if I decide to install an electric fuel pump or windows down the road. | | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Well you all have convinced me after looking at the mass of unlabled wires one last time. I have gotten so frustrated with my lack of progress with the wiring I'm going to cut out what I have one order a purpose built harness. Most likely from EZ2wire. I like their philosophy and the products look pretty good.
I'll be calling them today to get my final questions answered and placing my order. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | When you do get your new harness, take your time and DON'T cut any wires. EZ has been around for a good while and know what they are doing. If you get stuck, reread the instructions and/or call EZ. They will help you! Please feel to post questions here as well. You'll need to be able to solder and use Heat Shrink tubing, but that is basic and easy to do. You CAN do it!
best wishes,
Les | | | | | Joined: May 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: May 2012 Posts: 37 | Thanks, Les. Luckily, I have learned to solder during my years as an Amateur Radio Operator and have my heat gun all warmed up.
I know I have dithered on my selection of which vendor to go with, and I think I have finally settled on my choice. I have based it on communications with people like you, who have personal experience with the products, local information (my "mentors), and even contacting the vendors themselves. I was particularly interested in the clarity of their instruction packets and the level of technical phone support.
You may be surprised at my selection. I'll be sure to let you all know how it goes. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | One thing for sure, EZ wiring kits are quqlity & easy to follow. After a few glitches,through no fault of the harness supplier I finally have everything working good! One thing that may help is to make sure your battery is putting out 12 volts or more under load. I had a battery that charged up to 12.65 volts but only produces 9 volts under load. Also as mentioned before grounds can drive you nuts! My advise would be to make sure the battery is putting out proper voltage before trouble shooting grounds. Good luck and don't give up.
