0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | How does one determine if new shocks are needed frt/ rr on a 57 3100? I get a bit of bounce/ wonder when driving though in the drive when I push down on any corner of the truck it seems to only bounce a few times, but then again the suspension seems to kind of do a little 'hula dance' and not move just up and down.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | shouldn't be any 'bounce', especially a few times, and certainly no 'dancing', time to do a good check of all your suspension, probably find worn shackles
Bill | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | IF you get the truck bouncing up and down, when you stop, the truck should bounce no more than twice. If it does, time for new shocks.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Thanks guys, I will put the frame up on jacks tomorrow and see what I find on movement within the suspension. Truck has been like this since I got it little over 10 years ago, and the front axle was gone through when I put disc brakes on a few years back. I will report back... :-) | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Vroom
The test I mentioned above needs to be done with the truck on the ground.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2006 Posts: 122 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 122 | Ok, then how do I determine if the shackles are also a contributing issue? I get a lot more side to side/ front to back movement then true up and down movement when I am pushing on a corner when all four wheels are on the ground. Thanks. | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Shackles are not really going to contribute to your issues. Is the chassis on your truck stock? I know there was a stabilizer bar on the rear that may have some worn bushings. Also what condition are your kingpins?
The shackles may be worn and need replaced, but I don't think they could be causing the issues you describe.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Its hard to tell with bouncing on leaf spring vehicles. The best way to test them is to take one end loose & pull& push it through the travel.If it offers no resistance its quite obvious its bad. Sometimes they are real stiff & make the ride rough. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
