1 members (Rusty Heaps), 114 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#864553 07/05/2012 8:56 PM
How does one determine if new shocks are needed frt/ rr on a 57 3100? I get a bit of bounce/ wonder when driving though in the drive when I push down on any corner of the truck it seems to only bounce a few times, but then again the suspension seems to kind of do a little 'hula dance' and not move just up and down.
shouldn't be any 'bounce', especially a few times, and certainly no 'dancing', time to do a good check of all your suspension, probably find worn shackles
Flxible #864579 07/05/2012 11:07 PM
ODSS Lawman
ODSS Lawman
IF you get the truck bouncing up and down, when you stop, the truck should bounce no more than twice. If it does, time for new shocks.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #864671 07/06/2012 4:25 AM
Thanks guys, I will put the frame up on jacks tomorrow and see what I find on movement within the suspension. Truck has been like this since I got it little over 10 years ago, and the front axle was gone through when I put disc brakes on a few years back. I will report back... :-)
ODSS Lawman
ODSS Lawman
Vroom
The test I mentioned above needs to be done with the truck on the ground.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #866026 07/11/2012 12:06 AM
Ok, then how do I determine if the shackles are also a contributing issue? I get a lot more side to side/ front to back movement then true up and down movement when I am pushing on a corner when all four wheels are on the ground. Thanks.
ODSS Lawman
ODSS Lawman
Shackles are not really going to contribute to your issues. Is the chassis on your truck stock? I know there was a stabilizer bar on the rear that may have some worn bushings. Also what condition are your kingpins?
The shackles may be worn and need replaced, but I don't think they could be causing the issues you describe.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #866120 07/11/2012 9:59 AM
Riding in the Passing Lane
Its hard to tell with bouncing on leaf spring vehicles. The best way to test them is to take one end loose & pull& push it through the travel.If it offers no resistance its quite obvious its bad. Sometimes they are real stiff & make the ride rough.
1972 Chevy c10 Cheyenne Super
