| | | Forums66 Topics128,188 Posts1,057,331 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Tonight I decided clean up my radiator. I think it was a picture I saw that Woody had posted that has shown the rad top polished, so I gave it a go. I love the look. <pic> I'm thinking of painting the fins on the radiator an aluminum color, and the outside frame black. Were the fins aluminum coloured new? Mark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there was no aluminum in the original radiators, just copper brass and steel - and they were 100% flat black
Bill | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I believe the factory color is more of a Semi Gloss or Satin Black (chassis black), not Flat Black. Mike B  | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Using the wrong paint on a radiator can cause severe overheating problems. It's a heat exchanger, and painting it interferes with that process. If you decide to paint the core, use flat or semi-gloss black, and spray the fins at about a 45 degree angle so only the first fraction of an inch of the fins get painted. Don't let the paint penetrate very far into the core. Jerry
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks Jerry - will do. Had planned to use flat.
But you've got me curious - does gloss paint act as an insulator? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Using the wrong paint on a radiator can cause severe overheating problems. It's a heat exchanger, and painting it interferes with that process. If you decide to paint the core, use flat or semi-gloss black, and spray the fins at about a 45 degree angle so only the first fraction of an inch of the fins get painted. Don't let the paint penetrate very far into the core. Jerry I don't see why you say this. It's heat transfer you're looking for. Sure, if you use a heavy ceramic paint it will plug everything up and be so thick that you won't get heat transfer. However, a glossy vs flat surface will not change your heat transfer. I can say this because I have gloss black radiators in all my cars and they don't overheat. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I remember radiator shops actually dipping them in black paint. Obviously not a good practice but so many things aren't. Now they don't paint radiators much at all or use aluminum and plastic but dip the entire car. Part of Hope and Change I suppose. | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Old steam radiators in houses are silver and they give off plenty of heat.
Joe | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | At the radiator shop I helped run in California for several years, we bought a special heat-conducting paint, and used the "spray the front edge" method to assure maximum heat transfer. Radiators work best with no paint at all on them, but most car owners don't like the ugly appearance of an unpainted copper radiator.
Different strokes for different folks- - - -if anybody else likes their way better, go for it. I've worked around enough successful professionals in the auto repair trade that I'm prone to do it their way. The guys who have to guarantee their work usually know what they're talking about. Jerry
