2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Where would the serial numbers be found on a civilian 1941- 46 Chevrolet ton and a half truck and if they are plates how are they fastened?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Those ID. plates should be on pass. side of cowl. Also the stamped number on motor (next to distributor) may be the VIN.
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Mine is screwed on, with clutch heads.
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | TC, I'm having big problems at DMV at the momenent so this helps. I looked at your diaghram and saw the different places for sn's on the truck, I did not see mention of a frame #. Beside the ID plate fastened with clutch head screws they are telling me there should be one more matching serial # on the truck but I'm in doubt that this is the case. Any additional Information you could give would be monumental in me dealing with the hostile @#$%^'s down at DMV. My truck is a former Army truck and the guys over on the military site are helping me as well but the similarites to a civilian truck are many so I'm looking for help here too. Thanks! -Mike-
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Chevrolet didn't start stamping the frames until the early 50's | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I believe Chevrolet started putting the s/n on the frames in 1955 (second series trucks). Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Shop Manuals (and the Technical Specifications manuals from the GM Heritage Center) describe where the serial numbers and IDs are located.
Maybe someone will find a documented reference to a frame ID for pre-60s Chevrolet trucks and post that information?
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Tim, I've never seen the frame s/n spelled out on paper, but I can tell you all of my 1956 Chevy Trucks have them. The Tech Specs for 1955 thru 1959 only call out the door post location... Any of you guys with 1955 1st or 2nd series want to let us know if you have the s/n on the frame? Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have seen frame markings, but I have not seen Chevrolet documentation for frame markings. Some states and some organizations marked the frames. It would be nice to see Chevrolet documentation. It seems to me that if the frame was regularly marked at the factory, the manufacturer would document that. http://www.1954advance-design.com/chev-specs/1956-t-ser.pdfhttp://www.1954advance-design.com/chev-specs/1958-t-ser.pdfThose of you who have a frame ID, does it match the vehicle/cab ID or the engine ID? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Tim, All of my 56/57 truck frame numbers match the Cab numbers. Also, I believe some where in the mid to late 50's all States stopped using the engine serial number as the identification number, it was to hard to keep things straight when the engine got replaced. Mike B  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, starting in at least '56 [maybe 55 2nd] the frame stamping was the vehicle ID number less the first [model] identifying digits - that is, it was the year, plant, sequence number, and the door tags were made from that to match, with the particular model ID added I've heard that there was no public documentation of that for law enforcement and insurance purposes, don't warn the thieves there's more than one ID number on the truck [cars too?] ... I believe it was '55 when the "vin" started generally being used for title purposes, which would coincide with the frame stamping change, adding a number that couldn't be removed like an engine number or door tag Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the info and for Bill's clear photo.. If there is no GM (USA and/or Canada) documentation, yet the frme ID was put on all vehicles at the factories, and the existence of a frame ID was not publicized for secrecy purposes (as if thieves would not quickly figure this out), it should be in (or near) the same place on all 55-2nd and later (let's say 55-59) Chevy truck frames?
What is the location?
Would people with 55-59 Task Force trucks please check that location and post the year and model of their truck and the code they found on the frame? Posting a photo of the ID would be bonus information.
This will move this recurring topic/speculation from anecdotes to a pattern?
There is no reason to doubt the use of frame IDs, and there is no doubt that some trucks have frame IDs (they have also been reported on 47-54 trucks, when no IDs were put on the frames of trucks I have owned). However, if a high % of 55-59 trucks have frame IDs, even this Doubting Thomas will no longer say "show me".
What is the location of the frame ID? Passenger or Driver side of frame? Bottom or top or inside/outside of the frame rail? Can it be readily found/photograped, once you know where it is located?
Please post a description of the location that would allow 55-59 owners to easily check their trucks.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tim - on every TF truck I've seen [or rather, bothered to notice], the stamp was on the drivers frame rail top web just about over the axle, pretty easy to see once the usual fog of grease/road sludge is gone .... that's been at least 6 '56-'58 trucks, don't recall the few 55.2's I've seen and don't think I've ever looked over any '59's .... that pic is from a friends '56 panel that has had power steering installed
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 56 J 011675
56 = 1956, year
J = plant = Janesville, Wisconsin, USA
011675 = 10675th truck off the line that year, in that plant
USA 1956 1/2 ton panel
We'll learn more as more gets posted.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | put on your glasses Tim, that's a J, as in Janesville - that panel was a radio repair shop truck from N Dakota, not Canadian .... I don't recall what [if anything] was on the 2 trucks I've had that I know were Canadian Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Bill
I hope people post information, so we can build a list. I will correct the mistake.
