| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | My next project is restoring my Dads 49 tow truck (that I learned to drive with) My question , is a 3/4 ton long bed frame the same length as a 1/2 ton long bed frame. The frame and cab need to be replaced on this truck and I have a 1/2 ton long bed frame available but not sure if they are interchangeable. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are completely different widths/set-ups due to the suspension pieces. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Chevrolet or GMC? If it's a Chevrolet, there was not a long wheelbase 1/2 ton until '55 2nd. GMC did have a long 1/2 ton on the '47-'55 1rst body, but I'm not famialiar with them enough to tell you what the differnces were between them and the 3/4 ton.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The frame on a 1/2-ton (GMC unique 100 model/long-frame, see picture of one I parted) This truck is simply an extended 1/2-ton truck with 1/2-ton suspension pieces. http://good-times.webshots.com/photo/2967102110102454676BWyNDCThis frame is going to be 46-1/32" wide at the rear. a 1949 3/4-ton frame at the same location is 36" big difference. It is in the rear where the major differences occur due to the heavier rear differential and spring set-up. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's why I didn't want to really say one way or the other, since I wasn't sure. On the '55-'59s, the long wheelbase 1/2 tons and 3/4 tons use the same frame.
