8 members (BudVanDeusen, TUTS 59, padresag, Otto Skorzeny, Gdads51, Nick in Manitou, Maybellene, 54farmtruck), 116 guests, and 3 robots.
Topics128,246
Posts1,057,762
Members48,474
#865493 07/09/2012 12:12 PM
Big Bolt Forum Co-moderator
I had to put in some 45° bevels on my insulation. Came up with this cutter. It's just two boards, a batter charger and a piece of stainless wire.
http://s527.photobucket.com/albums/cc355/Chevytwoton/styrofoam%20cutter/
1948 Chevy 2-Ton
I had to cut 45° bevels in my styrofoam insulation so I came up with this cutter. Just used two boards, a small stainless wire, and a battery charger.
1948 Chevy 2-Ton
looks like Paul may be having that problem Cletis brought up in the IT forum ohwell
I wonder if it is because I put in a link to Photobucket. It's always worked before. I will try Shutterfly.
1948 Chevy 2-Ton
I had to bevel my insulation for my garage foundation at a 45, so I decided to build a cutter. I used two scrap boards, a small gauge stainless wire, and a battery charge, along with some wood screws to hold it together. I screwed the boards at a 90, then drilled a small hole for the wire to feed through 4 inches from the intersection of the two boards. This gave me a 45 on the wire in relationship to the base. I used the battery charger at 6 volt. It would cycle off once and a while, and did this less at 6 volts.
I am going to place a picture link on a separate reply to see if it helps with the disappearing text.
1948 Chevy 2-Ton
1948 Chevy 2-Ton
Okay.... that seemed to work.. Let us see what happens with a Photobucket link.
1948 Chevy 2-Ton
oKay.... rebooting seemed to clear the problem.
1948 Chevy 2-Ton
That's a real nice ingenious setup using the battery charger for the hot wire.
We used to use those at work in 40' lengths or more cutting polyiso insulation in our roof crickets.
Great ingenuity!
Jeff
My 1953 Chevrolet
1947.1 Gallery
My buddy uses copper wire and a soldering gun to cut his surfboard blanks.
Moderated by  MNSmith
