3 members (60steve, sron48, dt235sd), 173 guests, and 5 robots.
Topics128,204
Posts1,057,288
Members48,467
Hey All
just a quick question on removing the gastank.
seat is out
seat supports (across the gas tank) are out
Question: Im assuming its just the two straps holding it in. Underneath the cab, the bolts look like they have cotter pins and springs. Are these the correct bolts? just checkin.
That should be all that is holding it in. I don't recall that mine had the springs and cotter pins, but seems like something that would be good to do!
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
On my 38 we had to cut part of the back of the metal around the tank. the metal to support seat wrapped around tank and we couldn't move tank enough to get it out of frame work. Looked like tank had been put in place then the seat base frame spot welded in. The straps didn't have springs and cotter pins. The cab mounting bolts did have springs on underside forward, on the rear cab mounting bolts the springs were inside cab. Your 46 may have a better system.
No springs on mine either, but you may have to unscrew the fuel shut off valve from the bottom of the tank. The valve was too big to come up through the hole in the cab floor on mine.
Scott
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
the bolts with the springs were for mounting the cab. sigh
i ended up having to cut one of the straps. i wil have to cut the three remaining bolts.
and oh boy, the amount of slimy junk underneath the tank, yuck.
im almost ready to take the cab off the frame. just have to remove the dash!
We must all be on the same beer!!
Yesterday I removed the seats from my '37 Maple Leaf (Australian Assembled) and removed the fuel tank.
I had to remove 3 large Garbage bags of rats nests , dropings etc, near made me puke.
The Tank straps were secured under the floor by 4 x 3/4 head nuts similar to a Mag wheel nut.
The other protruding bolts with the springs etc are Cab bolts.
Some things on this truck are different to US & Canadian models, in that they were imported as Chassis/Cab and the HOLDEN (GMH) assembled and fabricated the cabs, different door styles, windscreen etc.
All the best with your project.
