| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Want to swap a 3 spd on the column to a 4 on the floor. Is this just a matter of swapping transmissions or are the transmissions different lenths? Thank for the help. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Enclosed driveshaft? They are both the same length. I did the same thing in my 48 3100. I like the floor shift.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Yes, enclosed driveshaft. Thanks, that what i thought. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Just so you know ... If you swap for a standard 1954 4-spd transmission RPO 318B, you will probably never use the extra low first gear.
4-spd Gear Ratios: 1st = 7.06:1 2nd = 3.58:1 3rd = 1.71:1 4th = 1:1 Rev = 6.78:1
3-spd Gear Ratios: 1st = 2.94:1 2nd = 1.68:1 3rd = 1:1 Rev = 2.94:1
I like my 4-spd. Syncro in 2nd, 3rd, and 4th. So by not using 1st, it's like having a full syncro 3-spd tranny.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You might find yourself using that first gear in a "slowest truck race", driving up the side of a barn wall, or towing/pulling a vehicle out of a ravine.
You might also find yourself using it if you convert to 3.55 ring & pinion gears and you are carrying/pulling a large load.
