6 members (Bill Hanlon, Cletus1950, Rustnut, Bucker, 52Carl, frogfarmer), 81 guests, and 2 robots.
Topics128,178
Posts1,057,063
Members48,460
#864718 07/06/2012 2:33 PM
Want to swap a 3 spd on the column to a 4 on the floor. Is this just a matter of swapping transmissions or are the transmissions different lenths? Thank for the help.
Enclosed driveshaft? They are both the same length. I did the same thing in my 48 3100. I like the floor shift.
Dennis
Yes, enclosed driveshaft. Thanks, that what i thought.
Just so you know ... If you swap for a standard 1954 4-spd transmission RPO 318B, you will probably never use the extra low first gear.
4-spd Gear Ratios:
1st = 7.06:1
2nd = 3.58:1
3rd = 1.71:1
4th = 1:1
Rev = 6.78:1
3-spd Gear Ratios:
1st = 2.94:1
2nd = 1.68:1
3rd = 1:1
Rev = 2.94:1
I like my 4-spd. Syncro in 2nd, 3rd, and 4th. So by not using 1st, it's like having a full syncro 3-spd tranny.
- Lonnie
My '54 3104
You might find yourself using that first gear in a "slowest truck race", driving up the side of a barn wall, or towing/pulling a vehicle out of a ravine.
You might also find yourself using it if you convert to 3.55 ring & pinion gears and you are carrying/pulling a large load.
