3 members (Lostbuthaulinass, MNSmith, festerhairball), 99 guests, and 2 robots.
Topics128,057
Posts1,055,814
I'm new to Stovebolt and just picked up a '59 283 4spd, it has a generator hooked up and a 12V voltage regulator so trying to determine whether it's running on 6v or 12v. The wiring appears to be original. What is best way to determine. Thanks.
Chilton's says 12V and negative ground.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
all Chevs were 12V after 55 .... check a factory manual, for '59 you need the '55 shop manual and the '59 supplement, as well as the '59 operators manual
thanks for the info..the manual ref will help tons.
