| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | I'm new to Stovebolt and just picked up a '59 283 4spd, it has a generator hooked up and a 12V voltage regulator so trying to determine whether it's running on 6v or 12v. The wiring appears to be original. What is best way to determine. Thanks. | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Chilton's says 12V and negative ground. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all Chevs were 12V after 55 .... check a factory manual, for '59 you need the '55 shop manual and the '59 supplement, as well as the '59 operators manual Bill | | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | thanks for the info..the manual ref will help tons. | | |
