| | | Forums66 Topics128,210 Posts1,057,459 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello, What is the official name of this type of fastener? Picture of fastener The fastener is from a: 1954 Chevrolet panel truck drivers side rear side panel inner compartment, the fastener is for rear fender attachment. Is the nut holder spot welded into place? How is it held into place? Thanks | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | I may be wrong , but i think its a "capture nut"? Yes, its spot welded into place. Good luck with your truck, Marty | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | That's what I was gonna say, captured nut. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's a weld nut that's spot welded in a precise position, a captive nut is one that is inserted in a hole and held by knurling Bill | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | Is it one of these? http://www.mcmaster.com/#clip-on-nuts/=i6b898(most of the way down the page - "sqaure style") Dave Evans 52_3100
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Captive nut,cage nut,tee-nut,floating nut,retainer weld nut and they are spot welded in place. Ray Stanley sells them with his body panels. They look like this retainer nut and are 5/16" - 18 thread size and 2" long base. Ray Stanley Wheelwright Restorations 92 Pine Street Wheelwright, MA 01904 1-413-477-6467 Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello From the names that all you posters suggested. The closes I could come up with is pictured in these links below: Looks like Ford & Willy's army jeeps used them. 10th heading from top of page. Under: NOW AVAILABLE CAGED AND CAPTIVE NUTS http://www.debellajeepparts.com/mbpremier.htmhttp://www.thelongolivedrabline.com/body-captive-nut-38-24nf/294The thing is they have a square stamped tube on one side of the cage and I still have my fender on the truck so I can't see if the the other side of the metal the nut is welded to has a square punched out hole. If anybody has the rear fender off their 47-55 1st panel truck or has pictures of the original nut holes, check to see if the nut holes are round or square. The factory worker, after punching out the hole in the metal panel must of spot welded the nut cage onto the metal panel , then inserted the square nut into the cage then bent the tabs over to hold the nut. If they spot welded with the square nut in the cage, the nut would not be able to float. Thanks, | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Here is a picture of an actual retainer nut that Ray Stanley sells. Retainer nut I'm going to spot weld mine into place where needed. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I know it's not correct, but I have recently used T nuts, available at the hardware store, on another project. They are designed for wood, so I flatten the barbs, and tack them in place. Worked great for attaching floor panels to sub-floor.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | |
