0 members (), 50 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Hello,
What is the official name of this type of fastener? Picture of fastener
The fastener is from a:
1954 Chevrolet panel truck drivers side rear side panel inner compartment, the fastener is for rear fender attachment.
Is the nut holder spot welded into place?
How is it held into place?
I may be wrong , but i think its a "capture nut"?
Yes, its spot welded into place.
Good luck with your truck,
Marty
That's what I was gonna say, captured nut.
it's a weld nut that's spot welded in a precise position, a captive nut is one that is inserted in a hole and held by knurling
Is it one of these?
http://www.mcmaster.com/#clip-on-nuts/=i6b898
(most of the way down the page - "sqaure style")
Dave Evans
52_3100
Captive nut,cage nut,tee-nut,floating nut,retainer weld nut and they are spot welded in place.
Ray Stanley sells them with his body panels.
They look like this retainer nut and are 5/16" - 18 thread size and 2" long base.
Ray Stanley
Wheelwright Restorations
92 Pine Street
Wheelwright, MA 01904
1-413-477-6467
Tim
1951 3100 Chevrolet
Hello
From the names that all you posters suggested.
The closes I could come up with is pictured in these links below:
Looks like Ford & Willy's army jeeps used them.
10th heading from top of page.
Under:
NOW AVAILABLE CAGED AND CAPTIVE NUTS
http://www.debellajeepparts.com/mbpremier.htm
http://www.thelongolivedrabline.com/body-captive-nut-38-24nf/294
The thing is they have a square stamped tube on one side of the cage and I still have my fender on the truck so I can't see if the
the other side of the metal the nut is welded to has a square punched out hole.
If anybody has the rear fender off their 47-55 1st panel truck or has pictures of the original nut holes, check to see if the nut holes are round or square.
The factory worker, after punching out the hole in the metal panel must of spot welded the nut cage onto the metal panel , then inserted the square nut into the cage then bent the tabs over to hold the nut. If they spot welded with the square nut in the cage, the nut would not be able to float.
Here is a picture of an actual retainer nut that Ray Stanley sells.
Retainer nut
I'm going to spot weld mine into place where needed.
Tim
1951 3100 Chevrolet
I know it's not correct, but I have recently used T nuts, available at the hardware store, on another project. They are designed for wood, so I flatten the barbs, and tack them in place. Worked great for attaching floor panels to sub-floor.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
