9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd), 75 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#862491 06/27/2012 7:39 PM
Hey guys, ive been havin thoughts about this alot. And i have not seen anybody try it or talk about it. I have wire wheeled my frame and sprayed bedliner it. Its very nice but the thing ive been thinking of is. The underside of fender and everything gets hit with dirt, mud, and whatever else you run over and it gets scratched and all. What would yall think about tryin the bedliner on those parts? Just the underside. In my head it seems pretty good to keep from any scratching and stuff. Any opinions? Or tips on it? Anyone ever tried it out? If it goes all well i might just end up making my own type of undercoationg like bedliner but for the under pieces of parts grin
Chance #862497 06/27/2012 8:19 PM
Alot of people do it but it's rather permenant. If prepped right, it will hold up well,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #862561 06/28/2012 12:03 AM
It really helps to reduce road and engine noise. Another benefit is it prevents rust! Just be sure that everything is fully prepped and they COMPLETELY hit the serious cancer areas such as the lower fender area by the cab and the upper front joint where the fender, inner fender, and core support come together. Rember that if assembled when done that the bolt heads will be covered, so that if you have to take it apart it will be a SOB to have to cut them out. You could A) mask the bolt heads B) have them sprayed off of the truck which is what I would reccomend, or C)just not worry about having to remove the bolts... just hope that no one hits your truck. Something to rember is that depending on how thick they spray the material can change panel alignment some if you do the panels seperately.
I plan on having the firewal, floor inner and outer, engine bay, fenders, etc done on mine when I get to the point. It should eliminate the big rust issues, as well as really calm the noise in the cab.
pope #863154 06/30/2012 1:05 AM
Thx for the advice. Ive already done my back part of the frame in it and it looks really nice. Wish i knew how to post pictures, so people could see the progress. Ill have to figure it out.
