8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 24 New Guy | | New Guy Joined: Apr 2012 Posts: 24 | Hey guys, ive been havin thoughts about this alot. And i have not seen anybody try it or talk about it. I have wire wheeled my frame and sprayed bedliner it. Its very nice but the thing ive been thinking of is. The underside of fender and everything gets hit with dirt, mud, and whatever else you run over and it gets scratched and all. What would yall think about tryin the bedliner on those parts? Just the underside. In my head it seems pretty good to keep from any scratching and stuff. Any opinions? Or tips on it? Anyone ever tried it out? If it goes all well i might just end up making my own type of undercoationg like bedliner but for the under pieces of parts  | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Alot of people do it but it's rather permenant. If prepped right, it will hold up well, Scott | | | | | Joined: Jun 2009 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 79 | It really helps to reduce road and engine noise. Another benefit is it prevents rust! Just be sure that everything is fully prepped and they COMPLETELY hit the serious cancer areas such as the lower fender area by the cab and the upper front joint where the fender, inner fender, and core support come together. Rember that if assembled when done that the bolt heads will be covered, so that if you have to take it apart it will be a SOB to have to cut them out. You could A) mask the bolt heads B) have them sprayed off of the truck which is what I would reccomend, or C)just not worry about having to remove the bolts... just hope that no one hits your truck. Something to rember is that depending on how thick they spray the material can change panel alignment some if you do the panels seperately. I plan on having the firewal, floor inner and outer, engine bay, fenders, etc done on mine when I get to the point. It should eliminate the big rust issues, as well as really calm the noise in the cab. | | | | | Joined: Apr 2012 Posts: 24 New Guy | | New Guy Joined: Apr 2012 Posts: 24 | Thx for the advice. Ive already done my back part of the frame in it and it looks really nice. Wish i knew how to post pictures, so people could see the progress. Ill have to figure it out. | | |
