Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#862407 06/27/2012 2:07 PM
Simple question today. How do I remove the ignition switch from my '49 chevy truck? I remembered the trick to get the lock cylinder out, but after that, I'm not sure. I stuck a paper clip in the little hole next to the key and the cylinder is out, but I'm not sure what to do next. Getting ready to paint the dash.
Not sure but I think it has a nut/keeper that screws on from the back. If you can stick a camera back there and take a photo and you should see it I think.
Give me ambiguity
or give me something else
If original, should be 2 screws on the back that you loosen, then turn the housing.
...pic...
...pic...
or you could remove the two bolts on the bottom and remove the complete housing, just remember a instrument light snaps in.
good luck
Thanks a lot, the picture is perfect! I think what I'll do is remove the bottom nuts, as I expect to replace all of it. I'll hang onto it all, just in case I need it.
