| | | Forums66 Topics128,022 Posts1,055,382 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 17 New Guy | | New Guy Joined: Jun 2011 Posts: 17 | Simple question today. How do I remove the ignition switch from my '49 chevy truck? I remembered the trick to get the lock cylinder out, but after that, I'm not sure. I stuck a paper clip in the little hole next to the key and the cylinder is out, but I'm not sure what to do next. Getting ready to paint the dash. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Not sure but I think it has a nut/keeper that screws on from the back. If you can stick a camera back there and take a photo and you should see it I think.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | If original, should be 2 screws on the back that you loosen, then turn the housing. ...pic... ...pic... or you could remove the two bolts on the bottom and remove the complete housing, just remember a instrument light snaps in. good luck | | | | | Joined: Jun 2011 Posts: 17 New Guy | | New Guy Joined: Jun 2011 Posts: 17 | Thanks a lot, the picture is perfect! I think what I'll do is remove the bottom nuts, as I expect to replace all of it. I'll hang onto it all, just in case I need it. | | |
